I thought the 2013 & on ST's and the 2013 RT's had the same exhaust systems - altho maybe that's just here in Oz?? :dontknow: After all, we do only get the RT mufflers on all the F3's?!? :sour:
Either way, I don't quite understand
what '
short pipe' you are referring to - as far as I can see there
is no '
short pipe' between the cat converter or eliminator & the muffler - at least not an OE Muffler - see the pic below! Come to that,
there's no angle between those pipes either - the entry pipe for the muffler bolts straight onto the end of the cat convertor or eliminator in what is pretty much a straight line... see the pic!
The cat eliminator is the 2 pipes in the middle distance that join into one, and its inlet & out let pipes are identical to those on a stock cat converter; the OE Muffler is bolted via the joint shown directly onto the cat eliminator - and that bit in the top right foreground
IS the beginning of the OE Muffler, which is all one piece (plus some trim bits....
So like I said, as far as I can see
there is no 'short pipe' between them,
and neither is there any angle between the muffler & converter - maybe that's something specific to
RLS Exhausts &/or their style of slip-on muffler?? Have you contacted
RLS about it?? That'd probably be the best source of info - there's a link to them down towards the bottom of the list of sponsors on the
Home page here.
