2013 ST Limitedlost access radio and Bluetooth after connecting Garmin zumo 660
Lone Spyder Ryder
2013 ST Limited lost access radio and Bluetooth after connecting Garmin zumo 660
Everything was working fine until I hooked up Garmin zumo 660, now I can no longer access radio and Bluetooth after connecting Garmin zumo 660. I did search on the site but did find anything, at lest not the way I was searching.
Leo
Not sure if you are having the same issue as me.
In my case, I have to make sure I turn on the SM10 and the SMH 10 first, then, once the radio has connected, I can turn on the GPS and all is fine.
If the GPS connects first, the radio does not come in.
If the GPS is connected to the Spyder GPS cable then you should not even be binding the GPS to your BT helmet as it will come out the SM10 and the GPS input to the radio will override anything the radio is playing.
Bob
Not the sharpest knife in the drawer!
I have the GPS plugged into the center mount. I don't have any Bluetooth connected to the spyder yet. Heck I have a hard time getting the Wii turned on and off. :opps:
