2014 RTL headlights not lighting up
UtahPete
Well-known member
On a recent ride my wife (driving in front of me) noticed my headlights were not on.
I've checked R6 by swapping with hers and that's not it.
I've not done anything to the bike since I last rode it a year ago, except to swap out the dead battery.
Any ideas of what to check next?
All relays & fuses. If fog lights come on when running should indicate most is working, double check /swap bulbs as well if not too much trouble. Maybe good time upgrade to LEDS:dontknow: would want know has proper power first. :thumbup:
I have LEDs for headlights and fog lights, so that's not it. Both headlights are not working so swapping them is not likely to accomplish anything.
I agree I need to verify power to them, but where to start? The 2 fuses that I pulled and R6 are good. Everything else electrical seems to be working.
Thanks.
Hey Pete. Which fuses did you check? Looking at your owners manual it would be Right side box JCase fuses, (the square ones) F4 and F5?
By the way, I had a premature failure of an LED lamp with my first set of LEDs. Pulled out the assembly, put in an old good bulb, it lit up just fine, got a replacement set of LEDs under warranty. Point is that it wouldn't be unheard of that they could have failed around the same time. Try a good bulb.
Hi Doug. I did not check those square fuses. Not sure how to remove them; do I just pull them straight like other blade-type fuses?
I suppose I could pull the Tupperware and check for power at the two headlight connectors. Thanks.
They come straight-out like the little ones. There's probably a special plastic tool that's preferred, but if you are careful, needle nose will do.
https://www.waytekwire.com/item/582/JCase-Fuse-Puller/
Ya if still have the old H bulbs:thumbup: Test with those, engine has to be running though. E51B230F-F513-4D6F-9E21-00B1E03320AA.jpg adapter for other bike also uses H4 bulb
If you have a meter go from ground to the low connection and see if you have voltage while the bike is running.
Okay, I've checkout R6 in the left box. It's good.
Checked out the following in the right fuse box, and they are all good; J4, J5, R1, R2
Nothing left now but to pull the Tupperware and check the actual bulbs. What do they say in troubleshooting; it's always the last thing you check, right?
..... What do they say in troubleshooting; it's always the last thing you check, right?
But surely that's ^^ only true if you actually find a fault/get a result??? :dontknow:
Cos if you can't find anything to fix or resolve the issue, then by default ( de fault of you can't find anything to fix! :p ) that particular 'issue' becomes an 'undocumented feature'!! This is widely recognised as a prime tenet of 'the BRP Method of Beta-testing'..... :rolleyes: :gaah:
Well, I'd better figure it out 'cause I've got no headlights working...:banghead:
The more you tell us, the more it sounds like it's gotta be a lack of power at the headlight globe plugs, or possibly a matching pair of blown globes??! :dontknow:
Any chance you could've had a rodent or two in there behind the headlights; or maybe have pinched the wires somewhere?? Still, either way, it does sound like it's time to pull the tupperware and get in behind those headlights to check things out.... Sorry. :opps:
I'll keep y'all updated as I methodically track this rascal down! But now, it's time to turn in for the night. Take another crack at it tomorrow.
Sorry to say my friend, there's only one way to find out and you have been dodging the the bullet, you have to dig into the lights and see if you have power up there!! I wired a four way switch in my house one time, screwed with that thing for two hours, just knew I had the wiring right to all those switches, but then started to second guess myself. After wiring and rewiring, my farther come by and said, Michael, did you check your bulb to see if it was good!!!!!:cus::banghead::banghead: Good Luck Pete!!
Make it as complicated as you like, but pretty much if you have the ability to hear the shutter cycling the wiring and power is likely fine. Change the bulbs and quit screwin around.
Bulbs should be the first check. If fuses failed or relays fail, fine, but not that common, AND for a fuse to fail it takes time to sort out.
Bulbs are known low life span items, just like front pulleys, fix it and be done. Not difficult, but if beyond your ability get help.
Thanks for the reminder to check for the shutter cycling between high and low beam. I thought I'd done that, but maybe not.
As for the last comment, I'm not ready to admit I can't do these things myself. When that's true, it's time to get rid of it I think.
