2015 SST Coolant Leak
dsteve931
Last winter and just seen yesterday after bike sits for a month r 2 , coolant leaks under vehicle on rt side-rode it all summer never added a drop in 9k ? Any thoughts?
Check the clamps on the radiator hoses as those are known to leak. BRP uses one time pinch clamps. I was able to tighten one using my center cutters and pressing it tighter with out cutting it. Most just use worm clamps as a replacement.
:agree:RH just in front of pedal almost under the radiator fill cap don’t know if the hoses are there on same side or if just where the low spot is for fluid to accumulate. But ya the clamps at water pump had issues on mine thankfully under warranty, still a pain.
