2017 RT rear trunk removal to fit extn USB cable - any instructions/hints?
dvpadgett
I need to remove the rear trunk so that I can access the USB cable so that I can add an extension cable and run it to the steering column. I removed the passenger back rest but the cable isn't visible.
Can anyone point to instructions on how to remove the trunk or would the wiring be accessible in the rear speaker compartment?
If the wiring is accessible in the rear speaker compartment, I just need to know how to remove the speaker. I saw three screws but they did not allow me to move the speaker grill or compartment.
Your help would be truly appreciated.
I did run a 10' cable from my trunk so I had power up front to support my GPS or phone. I have a 23 RT-L and did not remove my trunk or passengers backrest. I am not sure of the differences between bikes, but I used a coat hanger to run the USB cable to the area under the seat.
I did run a 10' cable from my trunk so I had power up front to support my GPS or phone. I have a 23 RT-L and did not remove my trunk or passengers backrest. I am not sure of the differences between bikes, but I used a coat hanger to run USB cable to the area under the seat.
Did you drill through it to get the wire from the trunk? I know I may possibly have to make a hole in the trunk or pull the wire through the existing hole. Please tell me with how you got to the wire?
No drilling for me. I took a pic with phone but it's to large for upload. There was a hole already at bottom
I just realized that I did not have to remove the trunk. Just the armrest/speaker module and I drilled a hole so that I could plug in the USB cable in the trunk. Thanks again for all of your help.
The cable I ran up to the dash was the old style mini usb. It will power my gps if needed. I purchased some adapters on Amazon which plug into that and converts it to a usb c for my phone. The cable on my '23 does not charge whatever I plug into it, so that's why I ran my cable.
