2018 F3 L Top trunk rack help.
JP58
Does anyone have a picture of the factory luggage rack mounted to there F3 trunk. Also do the 4 black metal washers go under the nylock nuts or on the top of the rubber washers. Thanks
First thing is the drill points are marked on the inside of the lid (the 4 dimples).
The metal flat washers go on the inside of the lid under the nuts.
Yes it has the 4 dipples. So the head of the bolts are up against the rubber washers then. I can't seem to find a close up picture of the rack anywhere. Brp website has no pics or instructions and didn't get any with the rack. Can't install till spring since bike is in storage. Still would like to see some pictures of rack from side view and top.
The instructions are on-line. There should have been a sheet with the rack telling you to go on their (BRP) website to view.
If you go to Lamonsters web site. Home page and click on his link. He has a link to BRP's instruction web page. Look it up by part number.
On top of the box it's rack, screw, spacer, rubber boot (spacer fits in the rubber boot. From the inside metal washer (I used fender washers to spread the load), and nut.
I found the instructions. It was hidden under a cardboard flap in the box. It's a very strange box.
