2020 Can-Am Spyder RT Timing chain synchronization - anyone have a pic of the cam/crank alignment marks?
Rafael
2020 Can-Am Spyder RT LT. I’m installing a new timing chain, and I can't remember how the camshaft and crankshaft marks align. I also can't figure out which of the three cylinders is at TDC. Could someone please share an image showing the mark alignment? Any help would be appreciated.
From the manual on my 2024. I hope this helps (Note: it says TDC on number 1).
View attachment 256930 - View attachment 256931 - View attachment 256932
Thanks for the diagrams; they helped me understand the camshaft timing marks, but I’m still not clear on the location of cylinder number one - whether it’s on the right side (where the clutch is) or the left side (near the timing chain)? As I understand it, the number one piston should be at its highest point. Please clarify this for me. Regarding the TDC locking plug for the crankshaft, I don't see any other one besides the large oil drain plug.
Looking at the third photo I provided they state No1 is on the clutch side of the engine. I did find a better picture for the knock sensor which is also near that hole to lock the crank. Also a picture of the locking pin inserted. Curious on how many miles you have an why you were changing the timing chain?
View attachment 256946 - View attachment 256947
Thank you, @jzeiler very much for the image, which helped me resolve the matter more quickly.
I want to share how to design the crankshaft locking pin so that it works perfectly. It is an Allen-head steel bolt.
Thickness 0.310.5 inches. Length: 3.275.5 inches.
