mecsw500
I bought a new 2021 Spyder RT Limited a few months ago.
Threw code C210A for the rear suspension on the way home.
Went back a few times, they discovered the rear linkage was not connected during the PDI.
Threw the code again on the way home.
Took it back, they replaced the rear ride height sensor.
Took it back, they found the Schrader valve leaking.
Took it back, they found an air leak.
Awaiting news as to what BRP say they are going to do next.
Only happens when I'm on the freeway at over 65 mph. Doesn't happen, even 2 up, on surface streets or in the canyons even. Doesn't happen for the dealer's tech as I assume he is lighter than my 240 lbs.
I'll call them again tomorrow. I'm a really mellow person and quite tolerant of what appears to be a difficult problem to solve, but even I am getting tired of the round trips to the dealer.
I guess the only things left are BUDS setting the correct height parameters, which I hope they would have checked by now, the compressor, or some lack of reliable communications with the suspension sensors to the main computer. I tend to rule out the latter due to the circumstances that cause it to throw a code, but you never know.
So, anybody have any ideas. I'm at a loss and wanting it to get fixed before the snow comes.
