Thanks to all who replied and suggestions for sources I hadn't thought of. My belt tensioner from Lamonster should arrive in the next couple of days, which will necessitate removing the same panels needed to access the strut and take measurements. If I find a replacement I'll be sure to post the info.
I found it unnecessary to pull off any panels to get the strut off. I ordered the replacement strut . referenced elsewhere in the thread from McMaster Carr. after it came I removed the worthless one this way. First I removed the back seat back pad. Then removed the rear seat. At this point the top of the strut is visible. I removed the 8mm screw holding the top of the strut and removed it from the plastic pin on the front seat. I now was able to flip the front seat all the way over into the rear seat space. now looking down, one can see the bottom of the strut mounted on the ball pin below. using a long skinny screwdriver, i slipped the blade into the slot on the back of the ball clamp and pulled the spring clip away from the back of the strut and easily pried the mount off the ball and pulled it out from the top. putting the new one in was this procedure done in reverse.
sure beats having to remove any Tupperware. Just have to mess with the seats. Just need an 8mm wrench, a long screwdriver with a skinny blade, and a flashlight. I hope this helps any of you fine folks out there. If it helps even one, i'm a happy old man!
Mark
ldpost: ALWAYS check the date of the thread & posts before replying Mark, ESPECIALLY that of the first post in the thread AND the date of the last few posts in the thread - your info certainly might be helpful to others searching in the future, so thanks for that :thumbup: Buuut, I doubt it'll actually benefit Iceman now, seeing that he posted what you quoted almost a year ago, so he's probably waaayy past pulling those panels
Why not get a new one under warranty?
Has anyone replaced the gas strut on their '20 or '21 RTL? Mine barely holds the seat open with nothing on it. I have a Butt Buffer and have to take it off everytime I fuel.
The original strut was shot when I got home with the Spyder brand new. How the dealership missed this is beyond me, as the tank was full. I didn't write down the info on the replacement strut or take measurements, but if no one has info on a stronger strut I'll start removing Tupperware.
I put the external spring on mine and it works fine but I think I may try what Chip did, why not get it completely out of the way.As usual, I have a different approach to the problem. I just disconnected the top of the strut and left everything else in place. Put the screw back in the plastic hinge so it doesn't wind up in a tire. The seat now folds back until it hits the trunk, but that's no problem. Eventually something else will motivate me to take the plastic off the left side and I will completely remove the strut.
Chip
2020 RTL
"Stella by Starlight"
That's a capital idea and easy to install as well.Mine did the same thing (I have since bought a Corbin seat). BUT before that I bought this size spring (see photo). You unhook one end of the seat piston, push the spring down over the piston and reconnect the piston... and the seat will stay up while fueling! I cannot take credit for this idea, I got it here on the Spyder Lovers message board!
Ok I have what I think is a suitable work around. Regardless of what Suspa stated in a email to me I did find one that works great. Suspa C16-14870 it is a 30# strut. I also was able to get the bottom and top ends off of the old strut so you can simply just use them if you want to.
I did replace the top link with another one which gave me about a 1/4" more lift at the stud which translated to a good bit of lift at the front of the seat. I like this better as you will have a little more room to fill it with gas.
Here's the best price that I found and as always with them I received them the next day. I'm sure this will vary depending on where you are located. Freight was a little under $8.00 so that also is reasonable.
https://www.mcmaster.com/catalog/127/1374 Part # 9416K14 in 30# You can choose another if you wish but it might break the plastic stud if there's too much pressure on it.
https://www.mcmaster.com/catalog/127/1376 The eyelet end that I used is a 6465K26 it is plastic but works great. You can always use the old one.
Here's on showing the extra length I got with the new eyelet end.
Here's one showing the new strut installed.
Here's one of just the new eyelet
Here's one of the seat lifted
