And hopefully those tabs actually catch the rear seat. Mine are there but they don't do jack. I can lift my rear seat off w/o touching the tabs (or even lifting the front seat). If it weren't for my backrest, it wouldn't surprise me if the rear seat just flew off. I have my 3k mile service coming up soon. I think I'll mention this to them.
On my OEM passenger seat, it engaged very easily (like it is supposed to) but on my heated replacement seat, the tabs did not want to engage at all. I played with it and wound up using quite a bit of pressure/weight to get them to finally engage. I haven't removed yet so I can't tell you why or what finally compressed enough for them to engage.
Hi
I'm a new owner thanks for the add
does anyone have a video or written steps to 2020 seat removal
thanks
I'm 300#. Even if I sit on the passenger seat, my tabs won't click into place. I think it's a design defect. When they were molding the seats, I think there were some that didn't fully cure or cured incorrectly causing the tabs to cure at the wrong (backwards) angle. Like I said, when I go in for my 3k mile service, I'll have them look at it. As far as I'm concerned, it's a warranty issue and they can get me a new passenger seat.
Sorry Cirhere, just a very brief hijack.....MONK, at 300lbs how do you find the performance of the stock shocks.....no bottoming out?
No issues at all. I have a base model RT so I have to fill the shock w/air on my own but when I rode it home from the stealer, it didn't have any air in it (my fault for not checking). Still didn't bottom out.
Take a close look at how the wiring harnesses are routed under the passenger seat. When I switched to a comfort seat, I had the same issue at first. Turned out that a couple of the wire bundles were not under the rigid clips they were supposed to be under, which prevented the seat from latching in the front correctly. There are "rails" that the disconnect plugs are supposed to be in also to keep them in the right spot.
Do you have a picture of the rails with the plugs in them?
Well, I was able to barely fit my arm under the raised driver(operator) seat to attach the compressor. Getting the extension on was a completely different story. My hands and forearms are too large to maneuver that well.
I may have to take the seat off to tighten the extension, or find someone with small hands and arms to do it for me. Pretty cold here today. So, I'll test ride tomorrow to see if the addition of air to the bag changes the ride. The compressor registered 0 PSI when I initially connected it. l added 70. I'm not that small of a guy 250+. Based on the manual that should be enough for me + another rider.
If anyone has a link to the post that has video of these little tabs that release the seat, that'd be great.
Oh yeah, I can tell now that the $10 spent on the valve extension was a great purchase.Particularly, if I'm going to add air to this thing every week or so.
Hi
thanks
Just took mine off, so I know pic's can be very helpful - here you go.
What confused me was that I thought the tabs were on each side - they're not, as you can see in the pic's...
Another question is that red piece on the bottom of the passenger seat. When the seat is on, that red piece sits atop a large switch. Is that a safety of some sorts in case the passenger decides to take a leap?
