Wmoater
This may or may not apply but I figured I’d throw it out there. I have a can am SXS. I plow with it, and we do go to WV- H&M in the winter occasionally with it if there’s no snow to ride sleds in the winter or spring. Its a 2019 and It has heated seats. On low heat settings it’s comfortable running at 3000-4000 rpm. On high setting it actually gets super hot and then kicks off for 3-5 minutes, gets hot again, kicks off for 3-5 minutes and does that again. My wife swears the 4th rotation and after it stays off longer. It definitely gets hot and cools on high. On low it seems to stay constant no pulsating. One thing to say is at idle if you turn it on and not sitting on it the seat doesn’t get hot. It only seems to get hot once it’s moving. The heat doesn’t disperse unless sitting on it. My sleds, wheeler and SXS have heated grips too, and they are constant and ridiculously hot on high. They never turn off or pulsate. The spyder grips don’t seem as hot. But again both my wife and I never run those on high either. We’re cold blooded and love the snow. So I’d say BRP put a thermostat in our seats for high on the SXS. I have Dave’s heated pads on my 17 comfort seat and they never pulsate on or off. Is it possible, and just throwing it out there that there is a safety heat thermostat before the relay so the relay doesn’t overheat if the grips and seats are on?
