2024 F3 Ltd - Is there a cover plate to go where the rear trunk sits if you remove it?
I have a 2024 Spyder RT Sea2Sky. When I bought my Spyder I received a large flat box that contained several things. The first was the driver's backrest and it's mounting hardware, but the biggest item was the cover that can be used to replace the top case if you remove it.
There's a section in my Spyder RT Operators Guide titled "Removing the Top Storage Compartment". I grabbed a copy of the 2024 Spyder F3 Operators Guide and there is a section with the same title in it. If you bought your Spyder from a dealer did you get a big flat box? If you bought it new and didn't get the box go back to the dealer and ask where the box is.
Here's a link to the parts diagram for a 2024 F3 Limited. It shows the top case on the left side of the diagram, and the cover on the right side as part 2000an Rear Box Cover.
The F3 SES doesn’t get a panel, and the cover you see in that diagram is the top box cover, not the F3T back cover….
I’m sure you can buy one, but the top on the F3 need additional hardware to be installed, so to put the F3T back cover on, you would have to take that hardware/brackets off every time...
