You ask "What are the chances of two fully charged batteries producing the exact same result??" If they're something 'less than high quality/high spec' products, then the answer to that is "A whole lot greater than you might think!" :banghead: And that chance is made even greater if one or more of them are 'brand new off the shelf' items, altho your putting it on a maintainer overnight beforehand might have a slight mitigation effect!!
Do you have anyone nearby who can/will do a load check on both batteries for you? Or failing that, any way (a multi-meter?) of checking the voltage of each battery:
If you can do those load tests &/or provide those FOUR sets of voltage readings for EACH battery, we might be able to shed some helpful light on your issues. :thumbup:
Still, the brief answer is that while the batteries in other vehicles might be considered OK if they load test &/or never show a voltage lower than 10.5 Volts in any of those readings above; but given our Spyders & their EXTREMELY power hungry nature, I've found that over hundreds of Spyders now, that
if any of those readings &/or load test results drop below 12 Volts ever, then you are likely to have the issues you describe! :banghead:
So if you're replacing a Spyder Battery, you really want the best quality battery you can get that fits, provides a minimum of 12 Volts, is rated for 350+ CCA, & 21+ Amp/hours - anything less in a battery means that it is most likely only a temporary fixture in your Spyder and very likely to cost you more than paying the extra for the higher quality/better spec battery in the long run, either for the call-out & jump start (IF you're lucky!) or for the tow home, plus any incidental accom & transport fees you may need to cover cos your Spyder Battery crapped itself when you were away from home!! :gaah:
Just Sayin!
- after they've sat for some hours off the maintainer doing nothing;
 - then shortly after you first turn the ignition on;
 - then when you're actually trying to start/physically cranking the engine; and finally
 - when the engine is running smoothly at idle after starting??
Just Sayin!
