Air compressor - anyone tried a Switch? & where is the fuse?
gerald37
Has any ever but a switch to turn the air compressor on and off on a Spyder. Mine just pumps up 90 lbs in the air bag. I like to keep the air bag about 20 lbs.It has been to the dealer twice. Last time they changed out the censor that regulates the compressor. It is a 2019 under warranty but I am getting tired of taking back to the dealer.I would like to just have 20 lbs in the air bag. I weigh 160 lbs and ride alone all the time.
Other suspension problem here: https://www.spyderlovers.com/forums/showthread.php?148764-Anyone-had-their-Rear-shock-leak-oil
Can anyone tell me where the fuse for the air compressor is at? I have found the two fuse boxes in the front trunk, but don't see a fuse marked for air compressor.
I'm the third owner of a 2014 RT-S and it came with the original owners manual which included fuse locations and functions. Perhaps BRP is saving money by not including such information in 2021 RT-Ls?
I have the operator's Guide. It has where the fuses are located but I don't see any fuse for air compressor.
gerald -- you are 100% correct -- the information isn't in the Operator Manual. Because the relevant component is a relay not a fuse which isn't in the Operator Manual.
For the 2014 RT-S it's LFB R4 Suspension Relay which is fed from RFB R4 Load Shedding Relay which is fed from RFB F5 which is fed from RFB J2 which is direct to battery positive terminal. Removing the relay might result in a fault code since its coil is driven by the digital cluster which might detect its absence.
PS my apologies for my inappropriate response to your very valid question.
Is there any simple way to disconnect the air compressor and not have it run? I just want to put 20 lbs. of air in the air bag and leave it. Nobody seems to be able to fit the automatic leveling system on my 2021 Spyder.
I'd suggest your best bet is to leave the compressor & the auto parts of the height levelling as it is pretty much system alone, but disconnect the air line going into the top of the air bag & the air line going into the Schraeder valve under the seat, and simply connect those two items with a single replacement air line running directly between the two! :shocked: That way it leaves the ACS as it is still 'operational' for all intents & purposes, just completely isolated, & by doing so avoids any computer conflicts/issues; but it still lets you add/subtract air to/from the air bag via the Schraeder valve as & when you desire, running whatever pressure you choose! :ohyea:
This might be a little more difficult than simply pulling a plug or a fuse, but as many here have found, it just WORKS WELL; and doing anything else becomes messy &/or difficult very quickly, with the potential for causing more problems than it resolves! :banghead:
In this case, expending a little more effort up front makes it & keeps it extremely simple from then on; and funnily enough,
KISS (Keep It Simple, Silly) REALLY WORKS! :thumbup:
What is the average pressure in the air bag carrying a person weighing 165 lbs.? Mine is showing about 70 lbs. The compressor wasn't shutting down and going over 90 lbs. They changed the sensor and now it is between 65 & 70 lbs. Now I get a fault code C21E1 very time I ride. I shut the Spyder off for a little while and there is no Fault Code, but it comes back.
Our 2018 F3-L needed to have the sensor reset. There is a process where the suspension is literally set on a block to establish reference point. The complaint was excessive bottoming out of suspension. After the reset, all is good. Ours doesn't have a pressure gauge on it to quote pressure.
I finally read the history of your rear suspension.
PMK's analysis is very telling https://www.spyderlovers.com/forums...ock-leak-oil&p=1636440&viewfull=1#post1636440
Your rear suspension and leveling system was damaged when the shock bolt loosened and the shock absorber failed. Likely the level sensor, linkage and even air spring (bag). While the sensor has been replaced, as pauly1 said it must be properly reset. But if mounting flanges etc have been damaged as PMK indicated was possible, there isn't a solution until that damage is repaired.
If your compressor is running continuously, you will soon be replacing it because the duty cycle is about 10% (ie, 1 minute On, 9 minutes Off) until it overheats.
If you are losing air pressure (say 2psi in 10 minutes) it's likely your air spring or air hose fittings were damaged when the shock absorber came loose. So back to the dealer.
Right now I'd say your summer riding season ain't looking good.
I don't have a pressure gage on mind, but I checked it with a tire gage under the seat. I just wonder what the pressure most people have. It would be higher riding two up.
gerald -- what is the objective of this topic?
Asking for a psi measurement most everyone doesn't know much care about?
Or fixing your obviously broken Spyder?
You bought a new Spyder, drove it 2K miles and discovered the selling dealer incorrectly prepared it.
Resulting in damage to the rear swing arm assembly including the shock and the automatic leveling system.
So you went to another dealer, earning negative loyalty points, and now they are just throwing parts at each increment of a series of problems just to get you to go away.
They ain't gonna do the deep digging to identify all the damage because you aren't a loyal customer and they are busy with the summer crowd.
So you have two choices.
(1) keep going back to the dealer to fix the next problem (probably the air compressor if it keeps running continuously as you seem to say) and then the next problem and the problem after that................ There's goes your summer riding season and maybe fall too.
(2) take it to a mechanic (probably motorcycle) who will dig into all aspects of the problem. You'll probably have to pay $100/hour and make sure you bring a service manual. Then take the list of problems back to the dealer and have them repaired under warranty.
While knowing what other people's ACS pressure is might be vaguely helpful, it's not really going to give you any specific or really helpful indication of what YOUR Spyder's air bag pressure should be to suit YOUR riding needs/wants, cos that pressure will vary in order to maintain your Spyder's pre-set Ride Height, & NOT to adjust the comfort or firmness or otherwise of your ride! :p
I've played with quite a few of these now, on Spyders ranging from 2010 right up to 2021, and the ACS doesn't set pressure as such, it sets the pre-set ride height, then adjusts the pressure to maintain that ride height as it varies, & the pressure can vary significantly between machines, even if they're ridden by the same rider over the same route in the same manner on a day with same sort of temps & conditions to every other ride! :sour: . You just don't know EXACTLY how your bike was set up vs how anyone else's was set up, and unless ALL of the variables AND the set-ups are IDENTICAL, INCLUDING the pre-set ride height and each individual rider's needs & wants, then you'd probably do just as well if not better by throwing a dart at a dart board while blindfolded and using whatever score you might get as your set pressure choice, cos as soon as you start to ride the ACS will adjust the air bag pressure to maintain the pre-set Ride Height! :banghead:
So if YOU think it feels better for YOU at 20 psi or even at 70 psi, you'll be negating the pre-set ride height for your Spyder, but you can do that if you want by just bypassing all the auto stuff that will either vary it &/or give you grief, install a direct air line from the Schraeder valve to the air bag, and use YOUR preferred pressure, adjusting as you feel fit when your load &/or riding conditions vary- and possibly adjusting your ride height too! :ohyea:
Just Sayin' :cheers:
+1 what they've said above. If you just want to ride and deal with the correction later, run a straight airline from the schrader valve under the seat to the top of the airbag, by-passing the ACS system. I did exactly that after the 2nd compressor fail and third check-valve failed on my 13 RTL. Never had a problem after that. As I'm heavy, I kept my manual air ride air bag set at 50lbs, if my wife was going on an overnight or longer road trip with me, we filled it to 90lbs (checked with a basic tire gauge) and if she thought it was too hard after a short ride then we let out 5lbs at a time till she was happy. But once that pressure was set, it stayed set for months unless I went and changed it. BUT I'd be pushing the selling dealer to replace that Spyder and cover all the costs you've incurred.. Contact BRP Customer Care yesterday. Get them working on it. They ought to cringe reading all the issues you've had. I hope your next Spyder is better than this one.
I have purchased five motorcycles from this dealer. I just was wondering if 70 lbs of air in the air bag is normal. I do get a fault code when I ride it. it goes way after the bike says for about 10 minutes. But like you say I won't post on here again.
gerald37...I have modified my air ride system to what I call "Air on demand"...I have a dash air gauge that shows the air pressure in the air bag...The dash rocker switch allows me to set my air pressure to anything I wish...The rocker switch also activates the dump valve to decrease the bag pressure...
I find for us riding 2 up the best static pressure is 80 lbs...That's setting still in the driveway with us both setting on the bike...If ride by myself I like the setting at 40 lbs...I weigh 260...
I WOULD ENCOURAGE YOU TO KEEP POSTING AND ASKING QUESTION...
WE HAVE LOST WAY TO MANY KNOWLEDGE AND TALENTED POSTERS OVER THE YEARS FOR VARIOUS REASONS...
larryd
larryd
Thanks for the come back and information. This was the information I was asking for. I weight 165 lbs. and my automatic leveling says 65 to 70 lbs. That should be good.
