Air - escape
Many brands
I rolled the spyder out of garage, Washed on it, Turned the key on to release the brake. And roled it back in.
Set the brake and - immediately on turning off the key ----- heard a instant Air escape. (sounded the same as
when you release a air pump from a tire) A distinct " Psssst ".
Never did have the engine on. Any ideas ???
I rolled the spyder out of garage, Washed on it, Turned the key on to release the brake. And roled it back in. Set the brake and immediately on turning off the key ----- heard a instant Air escape. (sounded the same as when you release a air pump from a tire) A distinct " Psssst ". Any ideas ???
It would help to know; a) which Spyder you have and b) how long you have had it.
Little checking
From your profile I see you have an RTS not sure the year but if you have the air compressor for the suspension it could be that without a load on the spyder at the time it let air out to level the unit.....:thumbup:
