Hi all I posted eirlier about my airbag, but now I explain it in detail.I arrived home yesterday after my RT SE5 Techno was serviced and I went to inflate my airbag with a hand held pump. I can't get air into the airbag and the reading was zero when I put a digital air pressure gauge on top of the Schrader Valve. This model Spyder can only be inflated manualy because it does not have the on bard compressor like the RTS. It feels like the airbag is blocked and will not let air in. The Schrader valve is working and the hose going down to the top part of the airbag is not blocked. there is a problem at the fitting on top of the airbag I think. Regards Peter
