This concerns all models of Can-Am Spyders: 2008-2014 GS/RS/ST/STS/RT/RSS/RTS AND WITH ANY TRANSMISSION: SM5/SE5/SM6/SE6
All these models have the same Caps and Diaphragms (BRP Part#219800058) that fit on the Brake Fluid Reservoirs. All Spyders and Models 2008-2012 had the Brake Fluid Reservoir BRP Part#705600735 or 705600549, and all Models 2013-2014 had Brake Reservoir BRP Part#705601072. Even though there was a change in 2013 of the Brake Reservoir, all the Caps and Diaphragms are the same BRP PART#219800058. I have three (3) Spyders. Two (2) are 2009 RS SM5's and one is a 2011 RT SM5. I have discovered that on my 2-RS's, that all four (4) Diaphragms in the Brake Reservoir Caps, had identical tears in them, v shaped. On the 2011 RT, only one of the Diaphragms had that v shaped tear in it, and the other had no tear in it. On one of the Rs's and the RT, brake pad replacements were done, and the Caps were removed while compressing the calipher pistons. The reasoning as to why you remove the Brake Reservoir Caps is that when you are collapsing the pistons, the brake fluid is filling up the reservoir and can cause pressure against the Diaphragm, with no place to go. This could cause a tear, BUT, on my other RS, which has never had a brake replacement done, there are that v shaped tear in both Diaphragms.
That tear in the diaphragm could cause brake fluid leaking down the top of the reservoir and down the inside of the Spyder and landing on the top of the rear Shock mount. In the past I have noticed brake fluid seepage causing paint to peel, BUT, to this time, I could not find the cause. WELL NOW I HAVE! IT IS TEARS IN THE DIAPHRAGMS
This is caused by what? Inferior manufacturing, Bad Rubber, ? Maybe the brake fluid runs so fast back into the Reservoir when you release the brake pedal, that the diaphragm can not hold the pressure? BRP needs to slow down the speed of brake fluid returning to the reservoir with a residual valve? VIOLA A TEAR
I HAVE FOUND, I HOPE, A BETTER REPLACEMENT OF THE DIAPHRAGM
DORMAN HELP! PART# 42081 Master cylinder gaskets These should be availabe at a good auto parts store. These dorman diaphragms look/feel alittle heavier/stronger. When I installed them, I can feel that are making a better seal , I had a harder resistance when tightening the caps.
PHOTOS TO FOLLOW: BRP-WITH V-SHAPED TEARS N New DORMAN diaphragms
Tom n Carol, SI,NY
Tom n Carol, SI,NY
