Am/fm antenna booster?
Mjhitman
I have a 2016 RT LTD and as most have commented the radio reception leaves a lot to be desired. I was wondering if any antenna booster is available to possibly help with the reception?
After I broke the OEM antennae ( which had bad reception ) I re-placed it with a Bosche manual retraceable Auto unit ( about $12.00 on E-bay ) ... I now get 15 or so stations in my home area in Vt. ..... It fit into the speaker housing by changing the angle slightly ..... But for you I would first try removing the antennae ( using a 7mm deep socket ) and cleaning off all ( or most ) of the yel. lok-tite ( it's an insulator :yikes: ) .... instead just use a STAR washer ..... also check the ground connection, these have helped many here with the same problem ...... good luck .... Mike :thumbup:
I just bought this from Amazon. Haven't installed it yet.
Bingfu Universal Car Stereo FM Radio Antenna Signal Booster Amplifier Amp,12V Power Supply Motorola DIN Plug Connector Adapter for Vehicle Truck SUV Car Audio Radio Stereo Media Head Unit Receiver
