CloverHillCrawler
Well-known member
I got my TricLED AfterBurnerz fitted but I am not happy with them. I have seen others post issues about the thin leads they use for their LED strips.
I went through and installed them following the PDF install instructions on the website as well as using the video. I went to do a test before closing everything up and I already have a bad strip due to a loose connection where the wire goes into the LED strip.
I am worried about putting my fender back on and causing more damage to the other strips because the leads are so thin and when I go to place the cables inside the fender to stow it, it will require some bending and twisting in order to make the harness fit in the area that is given.
Slingmods is waiting on an answer from TricLED about the warranty and will not issue a refund or exchange (which I am not really interested in) until they hear from them. I still have the LEDs on the Spyder just in case the only option is they will replace the broken strip, but I am afraid of closing this up with the leads in place and pulling it back off again as it will bend and break the leads if they are moved back and forth too much with how thin they are. In the meantime, it's frigging 70 outside and I can't go riding because I can't put my fender back on because of this and I now have to wait for an answer from TricLED before I can either pull these off and return them or deal with a nightmare of a replacement strip and more troubleshooting.
