�� I realize it’s sort of a dumb question but I was curious if there were any trends to be aware of. Apparently not. I’m looking at one with a bit over 50K miles so from what I’m reading here that’s not a big deal. It’s a very significant purchase for me so I wanted to consider future costs. Thanks.
Well, let's just say,
that's barely run in!! nojoke.  Mind you, if it's a 2014 that means an average of no more than about 5,000 miles a year, which is a little on the low side, and all that sitting around
might be a bit of an issue :shocked: So, what year is it?? :dontknow:
Still, as you're beginning to see/others have said &/or hinted at, if the Spyder you're looking at has been well maintained (& it hasn't had any major problems so far
 ) then that 50k miles is no big deal at all! :thumbup:
You should be able to check its service history/any outstanding work by asking a dealer to look up the VIN, so it's probably well worth checking that; and making sure it's not still running on 10-year-old petrol, oil, &/or tires & filters etc is probably smart too!
As for trends, the only real '
trend' that I can say I've noticed over the last 13-14 years or so has been that IMHO, the V-Twin RT's got better until the end of the 2013's, arguably the pinnacle of that version of the RT's (once the Heat Recall was done, anyway!
 ); and the 1330's were pretty much at their best from 2014 thru 'til about 2016/17; then, while the engine remained pretty good, they started a gradual decline in the reliability of the rest of their driveline, the fit, finish, and electronics after that; with the latest generation of RT's starting out strong in 2020 & basically becoming increasingly complex, 'plasticky', & more problematic from there on in!! :shocked:
However, that's just
my opinion, and I'm also pretty sure that I haven't yet seen any Spyder exciting enough or one that suits me/my needs well enough to coax me away from my (
slightly modded/ECU Upgraded) 2013 V-Twin RT, so I might be a little biased!
 . And I
do get to do quite a few miles on a variety of newer Spyders & Rykers... :thumbup:
Ps: Btw, my only real expenses over the last 10+ years on my Spyder have all been '
general use consumables'; things like fuel, oil, filters, brake pads, tires, a battery, & shocks/coils, in that order (I think?? Any I've missed?!
