Anybody Know where the main lead (constant on) wire is on the RT622 Trailer?
bullant12
I'm trying to connect a LED strip on the inside of the RT Trailer, but as I'm not exactly very tech, I need to know which is the constant on wire so I can connect a on/off toggle switch and the strips. Thanks!!;)
Not sure what you are looking for. There is not "hot" wire on a trailer. The running lights are on when the Spyder is running. That wire is orange, just like on the Spyder. Easiest place to pick it up is near the clearance lights, or remove the rear inner panel(s) and grab it at the taillight. The left inner panel is easiest.
Thanks!! I got to the left inner panel. I just wanted to know which is the running lights wire so I can tie in the LED and rocker switch. This should work.:thumbup:
