It is a great product and I use it when there is any sign of fuel problems.
but, I read that it is an alcohol based product and when you already use ethanol that may not be the best solution.
Startron may be a better choice for regular use ....
Here we go again, I keep posting about this but it seems no one listens.
It all depends on what you use Seafoam for. Seafoam by today's standards is an outdated product, albeit with a still loyal following from older users. It is simply 50% pale oil, 30% Naphtha, and 20% Isopropyl Alcohol. You don't have to take my word for it, see for yourself: http://www.mta.ca/administration/fa...Engine treatment - SeaFoam Sales Co. 2010.pdf
The pale oil is just an inexpensive base. Naphtha is a fairly good, if not somewhat dangerous (a known carcinogen) petroleum distillate solvent and is good for cleaning parts or helping to dissolve carburetor contaminants (thus the loyal following from older users). The Isopropyl Alcohol was used primarily as a gas line antifreeze, and drier. However now that most gasoline these days already contains 10% ethanol alcohol it makes absolutely no sense to add any more, in fact you should definitely avoid adding more alcohol or you risk initiating phase separation where the alcohol and water separate from the gasoline and sink to the bottom of your tank where they can cause all kinds of problems. Read for yourself: http://fuelschool.blogspot.com/2009/02/phase-separation-in-ethanol-blended.html
So:
Is Seafoam a good fuel system cleaner? Naphtha is a decent solvent so it may help clean very dirty lines but the much more modern, high tech Techron based cleaners with polyetheramine are far and away better, especially for fuel injected engines, so it really makes no sense to continue to use the antiquated Seafoam formulation to clean fuel systems.
Is Seafoam a good fuel stabilizer? Again the naphtha will impart some benefit to keeping dirt and varnish in suspension but the isopropyl alcohol is less than worthless for dealing with water issues and should be avoided. Both Stabil and Star Tron are far better fuel stabilizers and do not contain alcohol.
So why use Seafoam? Personally I have no idea, but by all means decide for yourself as long as you know the facts.
So:
So:
so what do u recommend? Thanx
