Given the Ryker has limited storage capacity has anyone considered the possibility of towing a small cargo trailer with the Ryker? I suspect the hitch mount would be the main issue.
Not supposed to tow with a CVT
CAN-AM ATV's with CVT are used to tow trailers, wood processors, logs etc. So I dont think the CVT is a limitation for any relatively light trailer.
If there is any way to safely attach a tow hitch is the main question.
Fabricating a hitch bracket to attach to the swing arm via the caliper mounting bolts is a possibility.
Vertical stress with two bolts may be OK with VERY light hitch weight.
Horizontal stress (turning) may be OK considering support from caliper plate.
Cracking the aluminum swing arm at the caliper mount could be expensive.
Bolts would need to be longer in accordance with the bracket thickness.
Stock bolts clear the caliper only by about one thread.
1/4" thick 6061 aluminum plate may do the job.
One vertical plate (shortest length practical) to the swing arm and one horizontal plate welded to the vertical, preferably with gussets.
Holes in the horizontal plate could be drilled if safety chain(s) should be required.
A cardboard mockup may be helpful.
See post three link in this thread
https://www.spyderlovers.com/forums/showthread.php?132357-Ryker-rear-fender-%93luggage%94-provisions
So glad of your input on a Ryker pull behind trailer. I’m very familiar with the Unigo single wheel trailer as I have pulled with my Harley and BMW Adventure. I think maybe the Unigo hitch system is over kill as it is designed to lean with a motorcycle which is not needed on a Ryker IMHO. A simple hitch would suffice as there is minimal lean, as similar to a car. I think a fabricator could come up with a frame mounted hitch system. I hope we get some more ideas on this. :thumbup: cueman
...Since the manual clearly states "NOT TO", think about warranty and insurance....in the event of an accident, I'm just wondering if the insurance company could possibly use that as a legality to deny a claim. Not saying they would, but just something to think about.
