Anyone had to replace their Ryker Battery yet? What with?
That may be the correct battery size for a spyder but this is the ryker section: YTX14L.
I'd recommend any factory sealed AGM battery; preferably vacuum-filled.
If you have the first month of production Ryker (Sep 2018?), you may want to start the summer with a new battery.
What is voltage, key off?
What is voltage, while cranking? (10.5 vdc or more?)
Chris, keep in mind that the OP is from Arizona, probably southern Arizona, such as Phoenix, with high summer temperatures.
My batteries in Southern California, 25 miles from the ocean typically had a 3 year life; but only 2 years in Southern Nevada.
Cranking voltage provides a field load test.
As for your battery, starting after 100 days (14 weeks):
A lead acid can self-discharge as much as 1% per day.
However, an AGM, new, only discharges ~2%/month and an older one ~2%/week.
14 weeks x 2% = 28% discharge or 14 weeks x 1.5% = 21% discharge
With a 12.6 voltage read, that would be a 75% state of charge.
This is based upon a clean battery with no discharge terminal to terminal and no consumption by ECU/ECM, etc.
Be interesting to know the battery voltage with battery at rest before the key on/first started.
Found this on Amazon
Energizer TX14L AGM Motorcycle 12V Battery,
200 Cold Cranking Amps and 12 Ahr.
Replaces: YTX14L-BS and others
