I looked in the Freedom trailers user guide concerning greasing the wheel bearings and found no mention of applying bearing grease as a maintenance item. It said the bearings and wheel hub are one assembly and to replace the bearings the entire hub must be replaced.
Question; are the wheel bearings sealed and no maintenance is required?
The manual stated to check for wheel hub/tire free play (sided by side movement) and ease of turning. If found then replace the entire hub unit.
Poasttown 2019 F3L, Freedom Trailer
