BajaRon front shocks for F3/RT models - are there different spring rates for varying weight loads?
troop
Well-known member
I received a notification from Slingmods about them now selling Baja Ron front shocks for F3/RT Spyders? They are manufactured here in the USA by JRI, which is a high quality suspension manufacturer. Ron, what else can you tell us about your shocks? Slingmods only offers one spring version. Do you offer different spring rates for varying driver/passenger/weight loads?
We prototyped various spring rates with light to medium to very heavy dual riders on a fully loaded RT pulling a trailer. We found a spring rate that works well in all cases once adjusted for weight.
These shocks have adjustable spring preload and a single point, easily adjusted clicking wheel which changes compression and rebound valving in the correct proportions together at the same time. This means the rider can find their sweet spot without having to know how shock dynamics work. Of course, we have worked closely with JRi who felt from the beginning that with their design, a single spring rate would work well for everyone. So, at present, there appears to be no need for a different spring set.
We are now beginning to work on rear shocks.
