Betwixt and Bewildered - how do I get the codes off 2008 GS?
Gary1952
I am 74 years old, and have been riding motorcycles, Yamaha, Suzuki, Indian, and Harleys, for over 60 years. Last year I bought a 2008 Spyder GS to see if I enjoyed riding it, and I did. The machine ran perfectly and when the riding season was over, in October, I put it on a tender and stored it for the winter. This season came around and when I went to start it, I found the battery was dead, so I replaced it with a new one. I started it up and it ran ok, so I decide to take it out for a ride. I didn't get 100 yards from my home when it started to stall and backfire and the engine light came on. I was able to get it home and watched some utube videos on how to get the codes out of it with no luck. So while I asked questions from other owners about how to get the codes out, they said the they thought the engine had to be running. So, I tried again. This time there was no code when I started it, so I decided to take it out again. I got about a 1/4 mile from home and the situation came back. This time it cut out and would crank but wouldn't start again. Had to have it towed home. Because of the age of the machine, I cannot get anybody to even look at it.
My questions to anyone here are: what can I look for; do I really need to have the engine running with the engine light on to get the code out; and how is this done? Any help would be appreciated.
Yes to see code the light should be on with the bike running. When you turn off the bike to codes reset to none and the codes go into memory. To read memory you need find someone or dealer with a BUDS setup. The BUDS setup can read all code that were set to memory in the past.
It sounds like you may have bad gas. if you leave gas setting, even 3 months without stabilizer it can go bad. That is the first place I would start. Drain and clean gas tank and change the fuel filter. How long was the bike in storage?
CopperSpyder gives a good place to start. With more information, a more precise answer may be possible. BUDS would be an excellent place to start. Even if a shop won't work on your Spyder, they should be willing to hook it up to BUDS.
It was stored from early November until early April. I always fill the tank using premium gas before storage.
I was able to find a guy who owns Second Wind Cycle who works exclusively on Canams for a Canam riding school here on Long Island. I called him and left a message and waiting for a call back. I will keep you all informed as things progress.
