Brake failure
Well....
That refers to low pressure in the brake system. Recommends checking for leaks or fluid levels. Thing is you would have some change in the brake pedal when applying the brakes. If your brakes are still the same it may be some other brake related issue. If not tech savy have the dealer check it out....:thumbup:
The low pressure code is more often than not a result of old fluid. You have flushed your brake fluid every two years as required right?
