brake light wiring colors
honsfun
Need to Know what the wire code is for stop lights??
BK---Wh ----GY/BB Which is positive feed? which is Neg? and which is switch
Thanks H
for a 2015 f3-6e6
At what part of the circuit are you asking about?
Based on the 2016 wiring diagram.
From fuse to brake light switch pigtail is red with orange tracer. Pigtail in is red. Pigtail out is black. From pigtail to Brake/Flasher module connector is white. Connector to module is white. Module to left tail light assembly connector is yellow. Module to right tail light connector is green. Both sides connector to brake/turn signal bulb is white.
