Brake Pedal?
retread
I did a quick search, came up empty. Does anybody know if there's a longer brake pedal available? I'm having to go almost pigeon-toed to get to mine.
Thanks,
john
Here is a picture of the one they speak of.
attachment.php
According to TriLed.com, the larger brake pedal will NOT fit on the 2013 RT model, due to the new floor boards for that year model. I know this because I called them to order a pair this morning, and he gave me that info. Will work on the 2012 and below models. Ken
Thanks,
john
John:
I also had a problem getting to the pedal with my size elevens but I found it wasn't so much the width of the pedal but the height. I had to put my toes on it and then it came dangerously (IMO) close to the floorboards.
I had a local machine shop make an aluminum spacer measuring 1-3/4' x 1" x 3/4" deep with two slots drilled in it. I put two longer mounting bolts in place and now the pedal sits high enough for me to access it much better.
