robmorg
I have a specific question for someone who has the BRP Bluetooth cable installed. This is the long cable that BRP sells with their version of the Sena SM10 bluetooth dongle that they intend to be mounted in the frunk.
Question is this... When listening to the bike entertainment system via a bluetooth headset, does the volume control on the handlebar multi-function control work AND does the automatic volume adjust setting (that adjusts the volume of the speakers up and down according to speed) work when using bluetooth instead of the bike's speakers?
The reason I ask is that I installed a shorter homemade harness from the radio to a Sena SM10, and everything works fine except for the two volume features above that seem to only work when using the bike's speakers. The only volume control I have available is the control on the headset.
. So I am wondering if there is more than one set of audio pin-outs on the radio, or if these two features are designed to only work with the speakers and not bluetooth or wired headsets.
