YIRYDE
formerly pman2011
Here are some pics of the location where I installed my BRP HID Ballast on my 2014. I don’t have any pics on the removal of the headlights since it’s the same on all RT’s. I removed them from my 2011 prior to trade in and installed them on my 2014. I was determined to get these lights installed once I verified they would fit.
BRP says these HID’s are available for the 2010 - 2012 RT’s and currently they do not sell them for the 2013 and 2014 RT’s. The Ballast gets installed on the 2010 – 2012 RT’s on a bracket located above the radiator.
I installed them on the grill (removing grill made it easier) that’s located behind the A frame. I used the spacers that come with the ballast and mounted them to the grill with fender washers on both sides of the grill. I probably didn't need the spacers and could have mounted them directly to the grill but I wasn't sure how much heat the ballast would put off.
I used high temp flat black spray paint and painted the ballast, washers and screws so when you look at the grill it would all be black. The adjustment is the same on the HID’s as it is for the stock headlights.
Ballast Painted
Ballast mounted to grill, side view
Ballast mounted to grill, inside view
Ballast mounted to grill, outside view
Ballast Painted
