Zero, if quick panel removal is a priority for you, these wind deflectors are a problem. They have an internal metal bracket which is too thick for 14mm Dzus, you would need longer. I'm not sure how long or if they are available. The bracket covers the joint between the "Can-Am" panel and the fog light panel. By preventing easy removal of the Can- Am" panel, it causes removal replacement of the oil reservoir panel and opposite side cooler panel to be a bit more awkward, as well. Finally, the screws supplied for the outside plastic of the deflectors require a 4mm Allen wrench ( go figure!) and the deflector itself is an awkward 3 piece affair. Some people have stated that the deflectors cause too much heat in summer ryding. I did not find that myself, but I mostly ryde in a northen latitude. I think the weather will have to be pretty cold before I put those ugly suckers back on my Spyder.
Thanks Neez.
Good info. I'll have to think about it a bit. Knee-jerk response is, I don't want anything else to add/take-off when working on the :spyder:
I really appreciate the info. Thanks again.
