Bushtec Hitch and Corbin Saddlebags
KenAcker
Does that combination work? Judging from the "look" of the Bushtec hitch, it appears to partially occupy the same space as the Corbin bags.
Nope. They were going to work together on something but I'm not sure if that ever happened.:dontknow: Call Bushtec and talk to Andrew.
Not Corbin but I have the GIVI bag system on my Spyder. When we were at Bushtec, I asked Andrew if their hitch would fit with the saddlebags I have. He came out, looked at my Spyder for about 30 seconds, held their hitch bracket up close to the saddlebags, and gave me a flat "NO" answer. After seeing Corbin bags in person and seeing that they mount in the same space, using some of the same attachment points, I would guess that the answer is going to be "NO".
Bushtec and Corbin Bags
I have been in touch with both companies. Corbin is working on a hitch -- it will be a Bushtec but designed to fit around Corbin bags. They have said they expect it to be ready in Jan.
Bushtec reports that it is preparing wiring harnesses that will work with the hitch.
ken tompkins
That sounds good. If it works with Corbin bags, there's a chance it could work with the GIVIs then.
If I remember correctly, I saw pictures of a Spyder on this site that had Givi bags and a trailer hitch, sure would like more info on that!
Waiting for Bushtec's 2009 offering is what I'll do (even if it doesn't hit the streets until early spring. I already own the Corbin saddlebags (although not yet installed) and I've had nothing but pleasant experiences with Bushtec in the past. Thanks for your reply Ken.
Ken
If Corbin is having Bushtec make a compatible hitch, I wonder it will be anything like my hitch. :dontknow: Mike took a lot of close up pictures of my hitch in Gatlinburg. nojoke Ryde Safe and Enjoy :thumbup:
sabunim5:spyder:
Well if they actually do come up with a hitch to work with the Corbin bags then they can sign me up. That's what I've been looking for. I don't want to give up the bags for a hitch... I'd just stay with the bags and just rough it.
Sounds funny doesn't it? I'm going to rough it with my $1,600 saddlebags. I totally agree with you of course. It just sounds funny. Hey ... have you had any water-leakage problems with yours? I've heard that from other Corbin bag owners.
Ken
Hey, the bags are totally worth the cost. We're going to use those vacuum bags to store our clothes in the cases when we go on our 2 1/2 week cross-country trip next year.
Nope, no leakage issues as of yet... but we really haven't had much rain this whole year.
mels towbar
You all amaise me, I have a Mels Monster Garage tow bar which fits onto the swing arm, it does not effect my Givi 35 Panniers and would not effect the Corbin bags. I have done over 12000 klm's on my Spyder with half of those Klm's done towing a 240 Kilo camper trailer with no problems what so ever. I have had the swing arm system checked by engineers and the bike shop that does my services, and guess what, no problems. The trailer tows straighter than a suspension type hitch. The other problem you have with a suspesion hitch is that the rear of the bike hits the rear mudguard, IE bottoming out unless you put on a stronger rear shock which makes non towing ridring a bit hard. We dont have Bushtech hitches here but have another company building the same style towbars for years. I have had their towbar on other bikes as other bikes didnt have the strength or facilities to fit a swing arm tow bar. I would almost bet that Corbin, a very inovative company will end up with a swing arm hitch. Alan from Oz.
If you are trailering with a suspension mounted hitch like the Bushtec and you are bottoming out, you have way too much tongue weight on your trailer. You need to redistribute the load in the trailer or buy a new trailer that is designed better. I think Bushtec's specs state that there should only be 35 lbs. of tongue weight on the hitch.
:agree: The standard rule of thumb for any trailer is a tongue weight of 10% of the trailer's loaded weight, no less than 10% of the empty weight, and no more than 10% of the gross weight.
-Scotty
Corbin Trailer Hitch
Has anyone installed one yet?
CA-HTCH Hitch carrier, Can-Am Spyder w/ Fleetliner saddlebags $399
I am looking for some feed back on what you think.
Thanks
Nexus
