Can anyone explain the Belt Alignment Procedure for a '22 RTL? Any videos?
USAF
My belt on my 2022 Spyder RTL seems to be a little out of alignment as it sits tight against the backside rear drive sprocket. Can anyone explain the process in setting the alignment or know of a video showing it done?
Thanks.
All you have to do is a search at the top right of the page, that should give you enough info to blow your mind, or you tube it! It's not that hard, just take your time and be patient. Is it tight, hard against the pulley? If you go down the street in a straight line, pull to the side of the road, stop and look at it, is it hitting the pulley? The belt's going to float back and forth on the pulley, so if you back up or make a turn and get off and check it, it can be on the pulley most likely, so only check it from a straight stop! You should have a space like a credit card there when you look at it.
