Can anyone help identify this part?
See photos. It came off while removing the left side footrest assembly. When I removed it, I thought it was in the wrong place. It clearly has two connecting points, but we could not find where it would go. Any help will be appreciated.
Ya, I think there is a post somewhere about putting your year make and model in your sig!! :unsure: ;) It does help! Looking at the captured nuts, I would have to guess it's stiffing something up that has been removed. When you took the last bolt out it fell on the floor! Just a guess, good luck!
Would help if you stated what year, model spyder it came from?
Sorry, it's a 2017 Spyder RT.
I. know, but I haven't been able to find it. Thought I had done that at one time.
I took a look at this. Thanks for the link. The part that seems to be where I need to look is a mess on my laptop. I can't see the part for the part numbers.
You are right. I didn't know it was there. It was like someone had used it to hold a bolt, but it was not meant for that because it should have done something else.
I was just looking at the picture, and I think it's the panel support#705007375!
What panel? I can find the reference but not the picture that shows where it goes. I thought it may be support for a panel but for what panel and where? It must have something it connects that is capable of giving panel support. I assume by panel you mean the plastic covering.
