UtahPete
Well-known member
I'm getting my ECU Stage 2 flashed. The instructions from Wick-It recommend either a CAT delete or a free-flow muffler or both in order to maximize the benefits from the ECU flash and to reduce exhaust heat. I don't have either (my exhaust system is completely stock).
Can you ICE experts out there explain about 'free-flow' muffler and which after-market products I should take a look at? I understand about the CAT delete and I will consider that, but I'm more interested in the 'free-flow muffler' as that is easier for this tree-hugger to consider.
Thanks.
USER NOTES:
It is imperative that stage 1 or stage 2 tuning along with specific air box or inlet modification never be mixed up or used beyond their intended development. IE: You can't run stage 2 airbox modifications with stage 1 ecu tuning. And you cant run stage 2 tuning without the proper air inlet modifications.
The dynamic tuning of the ecu allows the user the use of whatever exhaust configuration. Stock, Cat delete, free flow muffler etc in any combination. However, it is recommended to have either a cat delete or free flow muffler with the stage 2. Or both. A well flowing exhaust both works better for power and just as importantly retains less heat around the bike and engine compartment.
Stage 1 is a premium fuel 91 octane tuning. But users can use 87 octane in an emergency and follow safe engine driving habits with the fuel. (keep rpm up, use low gears, don't lug engine, stay below half throttle) Higher octane fuel can be easily used, use what works best.
Stage 2 is a premium fuel 91+ octane tuning only. NEVER use 87 octane.
Through the use of advanced logic, temperature sensors, knock sensors, oxygen sensors and torque calculations, power will be limited without ideal conditions. The use of poor fuel or exhaust configuration, or high temperatures will have power limited. Just because something works, doesn't mean its ok or ideal. Let the engine breath and feed it the proper fuel. And you will be rewarded.
Thanks.
USER NOTES:
