Check DPS Fault
Matt maybe you should start your own thread on this and you may get more reply's!! Some people will not go to the end of a old thread to see why it was drug up out of the deep!:2thumbs: Good Luck!
Matt I think you should be showing 13.4 Volts at idle and if you are only showing 12.7 you may be short on voltage when maneuvering at low speed in your driveway.
