Code issues
GreenDragon
My 2014 RT has been running great, no issues on the dash. Dead battery and had to get a jump. Have new battery now. Took it in for oil & filter change and the shop tells me there are codes popping up but not active, they clear them and when the bike is started again, the codes show up as active. Nothing ever shows on the dash. Any clues or help would be appreciated? I do not know what codes, but am going to try and find out today. Thanks.
Interesting. ...🤔
:agree: hard to say without knowing the codes. Many codes are stored without you knowing about them but once stored they are not an issue anymore and a reference to the tech/brp to look into. If they reappear as active then there is an issue that has not been resolved and needs to be addressed. We have glitches which are codes that appear but clear when shut down and never come back and never were an issue. If you get the free app " spydercodes" you can look up the codes and see what they are and what should be done....:thumbup:
With the key on push the Mode, Set and Turn Signal Cancel buttons all at the same time. If you have an active code it will be on the screen, if no active codes the screen will be blank.
