I only have Spyder Codes info for the older (pre-2018) models, and since you haven't told us what year & model of Spyder you're talking about, I can only assume from your post back in May 2015 that it's a 2014 RT... (Which is why I moved this thread here.
) If that is the case, that particular code is not shown on any of my Spyder Code listings.
Not that it helps much, but are you sure it's a '
V' and not a '
U'?? Error Code '
U0416' is a fairly common automotive (non Spyder/BUDS) code for a VSS error, but I really don't know if that applies here...
The later models may have that code in their onboard programming &/or in their diagnostics, in which case someone with those models or access to that generation of those codes may be able to help more, but I cannot. Sorry.
Maybe to help us help you, you could follow the directions in this thread:
One off our members has sent me a private message requesting the following:
Would you ask all members to provide information about their Spyder/Ryker year, model in their signatures.
This will go a long way in helping people determine a good answer to questions that get posted, and do not appear in a specific forum for the product.
This will provide a quicker and more accurate reply in quite a few situations.
Page 7 of the thread, post #129, and
ADD your Spyder model and year info to your sig line?? That way, it will appear on every post you make, so readers will know at a glance which Spyder you're asking about.
