Does it happen
ALL the time you're stopped at idle & in gear with the Park Brake off? Or
just intermittently if/when you're stopped like that in gear with the Park Brake off??
If it's the latter, then it
REALLY sounds like it's just the
normal operation of the air compressor for the air bag doing its thing, and it'll probably make a noise every time you move enough to change the height of the suspension &/or bounce on the seat. The compressor won't operate until you start the engine running, release the Park Brake, and put it in gear... but then it will adjust the air pressure in the bag in response to
any change in the ride height, possibly even a change as small as you shifting on the seat, &/or just coming to a stop and the bike settling at idle. This is normal, and not an issue. There are ways of testing for correct air compressor &/or air bag operation already discussed here on the Forum at length, which should be readily found if you search '
Air Compressor' most likely with the '
Search titles only' box checked, and I've added a link to one thread down a bit, so I won't go into it any further, but
if it's your air compressor work occasionally and not continuously, then you're good to go! Here's that link (look at post #7, I think):
https://www.spyderlovers.com/threads/how-do-you-tell-the-rear-air-compressor-is-working.155418/
However, if your 'noise' is happening
ALL the time, ie, the first thing I mentioned in the first para above, then it's probably not the compressor, at least not unless the air bag or air lines are leaking &/or the height sensor isn't linked or is set incorrectly. For more on that possibility, search on '
ACS' or '
Air Bag', '
Air Compressor' in thread titles and look for titles mentioning/suggesting the thread might be discussing the Air Compressor operating all the time, but since you tell us you've already had the air compressor replaced, I'd hope that whoever did that checked that the ACS was working correctly then and that it's not that again!?!
That's not to say that it couldn't possibly be that, but more sorta
hoping for you that it's not!
So if it's not that, then maybe this is a bit out of left field here, but could it possibly be a leaky exhaust??
To check for this, can you get someone to sit on it with their foot on the brake while it's idling? If you can, then get them sitting there with the RT running, just like you would at a stop light when you can hear this noise; then you get down on the ground and both listen carefully and pass your hand close to but without touching around/near all of the exhaust pipe alongside & under the RT, feeling for the blow-by caused by any leaks. It's probably best to do this just after starting it and before you ride to far, just to minimise the chances of burning yourself - or maybe YOU should sit on the bike & get your helper to check for leaks?!
Like I said, the exhaust leak thing is a bit out of left field, but if it's not the air compressor doing its normal thing (and I'm sorta inclined to think it is...) then there's not really all that much else it can be without starting to look at the clutch, transmission, &/or engine. I do hope, for your sake, that it's not one if them...
Good Luck!
