StanProff
I had these codes Saturday after a 430 mile day, I found a post with the same codes. Anyone know if the cause was found or a resolve? My comments are below M109Dreamer's post. I sure hope it is not the sign of some bigger problem, I have over 20,000 trouble free miles on my 2010 and have loved every mile.
Did you get a resolution to these codes yet?
I have been trying to look up the same 3 codes when I ran across your post. I got a limp mode and the screen flashing a DPS warning alternating with the little engine warning. I checked the codes while driving, same as yours. The screen was flashing back and forth from the pic of the handlebars to the engine warning pic. I was about 10 miles from home after a great all day ride in the West VA. mountains, Virginia and Tennessee. 430 miles total. Mine is a 2010 RTS with a little over 20,000 miles on it. Today did consist of a lot of mountains and curves. The last 150 miles home was at interstate speeds above 70 mph. It also looks like the VSS light is lit up, the one that looks like a Spyder swerving. It is the first time I have driven with limp mode engaged, it limits the rpms to about 3800 to 4000. That means you might do 50 mph in 5th gear, but that's all it would do.
Stanproff
Originally Posted by M109Dreamer![]()
Well on the way home tonight we got the orange screen "DPS Fault" then a 100 feet later Limp Mode with the following codes.
C0051
U0122
C006C
I have read the threads that have talked about similar codes. And I didn't catch the results from anyones issues reported back as the cause or fix. The last time anything was done to the Spyder was back in Nov13 when we had the laser alignment done. Other than that nothing has been done to the Spyder.
Is there connectors, and where would they be located for me to check.
I am assuming that I need to take this to the dealer correct? Any suggestions?
Stanproff
