AndysF3S
I just received my new LS2 Advent X modular helmet and decided to compare it to my 2 year old 509 Delta Ignite full face helmet which is more suited to cold weather(winter) riding.
LS2 257 Modular 901-1035 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 509 Ignite full face helmet F01003301
Wt: 3.9 lbs - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - --- - - - - - - - - - 3.9 lbs, includes breath deflector and chin
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - curtain; it would be slightly lighter if those were removed
Certification: ECE 2206, DOT FMVSS 218 manufactured date 12/23 China - - - - - - - ECE 2205 manufactured date 8/21 China
Lens: Clear, pinlock FF901 incl as well as light smoke tint outer lens - - - - - - - - - - - Heated clear lens with cord for connection (less
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - peripheral view because of heated element)
Inner shield: light smoke tint (good for bright sunny days) - - - - - - - - - - - - - - - - - Yellow/orange tint (better for low visibilty conditions)
1/2" wider (due to the lower module being able to move over and back) - - - - - - - - - 3/4" longer
Fastener: ratchet type (two handed operation with trial and error, no gloves) - - - - - - Magnetic type (two handed
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - operation with trial and error,
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - no gloves)
General:
Both lenses snap down to seal the front facial area, the upper lens tab for the LS2 is on top not on the side and will take some getting used to.
Both of the internal visors are operated by a similar slide assembly on the side of the helmet.
Although both helmets are an XL, the full face (509) fits looser on the head and moves just a bit with side to side or head movement. I can wear the 509 with a balaclava if I need to, the LS2 would be too tight. The LS2 is easier to put on or take off with the front jaw protector up out of the way.
The LS2 has a snug fit with no movement. It has a thicker inner pad that I can feel all over much like a liner that could be aired up. I hope the padding relaxes a bit as the firm fit could be uncomfortable over a long ride, so I am wearing it around the house to see if it relaxes a bit.
The 509 has forehead vents (2) that provide decent air flow but no chin vent. The LS2 has a large forehead vent, chin vent and a vent closure at the back to reduce air flow. I hope that the venting is sufficient when riding in hot weather, considering that the LS2 fits more snugly.
The 509 prevents lens fogging if you open the front shield just a bit and I have never used the heated element even in winter, the LS2 should be the same.
The 509 is quieter than open face helmets but I expect the LS2 to be quieter yet, as the fit around the lower part of the head is much tighter but not restricted in the ear area.
I do not expect to use the extra tinted outer lens or the pinlock antifog lens that were included in the package. Both helmets came with a soft helmet bag for protection but the LS2 also included an outer helmet bag with zippers and back straps to allow you to carry the helmet on your back or perhaps carry a second helmet on a 2-up machine. Neither helmet will fit in the Shad bags.
I do not use a communicator so neither has one installed.
The weight that I found for the LS2 in the large shell is 1600 grams +/- 50 grams and the actual weight on a new digital food scale is 1776 grams/3.9 lbs. The Carbon X is supposed to be about 130 grams/5 oz. lighter but I did not buy it because of the extra $100 CDN; and because I ordered online from a supplier in Quebec, I was unable to try either; no local shops seemed to carry the LS2. Given hindsight and the fact that my neck doesn't like a heavy helmet, I would probably have bought the Carbon X.
I will update the feel at highway speed as well as the wind noise in a couple of weeks once the snow disappears. Hopefully the pictures will show the similarity/difference between the two.
General:
