Connector for Front Turn Signals
NetJunkie
My left turn signal went out a while back right before my 600 mile service. Dealer fixed it while it was there and said the connector had come loose. A week later it's out again and I want to check the connector without going 45 mins to the dealer. How do I get the mirror/signal off to check that?
The connector itself is actually behind the cluster. Pop out the cluster and the plugs are right inside on the bottom. Black 2 wire plug. One for each side.
Sent from my SCH-I545 using Tapatalk
Thanks! Well that was easy...and..it's not the connector. Just my luck. A week after fixing that the bulb actually goes out (swapped to test).
Is this the right P/N for the front turn signal bulbs? 410922994
Is there a replacement I can get local?
I don't know about the part number but it should be any easy one to match up at any auto parts store.
Turn signal connector
I had a similar problem with my STS. The connector that came loose is up in the fender wheelwell. Is it a led light on the RS ? On the STS its a led light and the dealer said they should not go out, so it might not be a bulb
Or I could use common sense and just look at the number on the bulb I took out. :) Thanks again.
Assuming there is a number there. Knowing BRP they scratched the number off only to put their own number....:D
