Unfortunately, I have a story to share from about 2 years ago. Normally, I am very aware of deer and learned how to watch for the "glow" of the eyes in the trees at night and to watch for leaves on brush near the road moving during the day, especially if there is no wind.
I have shared this on here before, late night after installing new brakes, I went out at 1:00 am in the morning to sinter the brakes. I didn't want to go out on the highways to do my 3 stops from 50+ mph down to nothing and have traffic behind me, so I went out on a long straight back road near me to do it where there's only a couple of houses on it. I had done 2 stops and was in the process of doing my third run. Right when I hit the brakes to do the 3rd stop a deer (buck) jumped out from behind a panel truck that was in a driveway.
I got lucky and didn't really hit it, as when I came to a stop the frunk was right underneath the belly of the deer and my fenders kicked its legs out from under it, so it fell on top of the frunk and windshield with its body and it's head slammed against the left fender, breaking the plastic on it and bending the struts against the tire. I had to grab the struts and bend it off the tire by hand to get it back home.
Since then, I have found other pieces damaged, like the nosepiece, and I am currently now fixing cracks which have spider webbed out from the windshield mounts on the windshield, and then I will paint both sides to hide the epoxy repair. I got lucky, and so far have only had to replace about $500 worth of plastic and fender struts.
Alignment and frame/chassis were checked when I took it in for an alignment after I completed the repairs and everything checked out good.
I was pulling deer hair off of it for a couple a months afterwards, as it seemed to get stuck in every crack, and wherever the deer fell against the Spyder I had to use to McGuire's scratch remover/polish to get all of the scratches off from the hair. It's really abrasive!
My advice - if you are going to hit one aim right in between it's legs if you know you can slow down enough not to have it break the windshield on to you. I didn't try with mine, but I'm glad it happened the way it did. I have heard of much worse happening, as noted in the posts before me.
