dess
ssmcclub
Is there a fix for the dreaded dess showing up on your screen it happen on my 2014 rss spyder today would not start took key out and put it in my house about 40ft away,waited one hour and it did start up,is there away to fix it thankyou:(:(:(
Yes, their is a fix for the DESS showing up on your 2014 rss. Read the thread" D.E.S.S. KEY CODE AGAIN!!!!! started by Deanna777 on 8/13/15 This thread has some good info. on the D.E.S.S errors.
also read D.E.S.S. KEY CODE PICTURES ON A 2014RTS-SE6 started by Deanna777 on 7/12/15.
1. take a picture of the D.E.S.S. error.
2. Do you have any warranty left on your spyder?
Take your spyder to your can-am dealership get it fixed. If you have warranty on your spyder, the D.E.S.S module need to be replaced, and it is under warranty. I have had the D.E.S.S. Module replaced twice ( I have a 2014RTS-SE6)
Deanna
ok thank you went down to my dealer today and ask him about the dess problem,he look it up and said he will order me a new dess modell and replace it soon as he receives it hope it will work let you know thanks again:yes::yes:
sometime the DESS problem can be fixed by someone with BUDS relearning the spyder keys.
Cruzr Joe
Cruzer Joe,
Have you been following my Thread " D.E.S.S. KEY CODE AGAIN!!!!" that I stated on 8/13/15( Deanna777) and the first thread " D.E.S.S. KEY CODE PICTURES ON A 2014RTS-SE6" that I started on 7/12/15???
Yes, are right about the BUDS.
Deanna
