Did an upgrade Sway Bar improve your handling? Which one? And what about Shocks?
Putting just springs on the front is better on the pocketbook, but you've got to remember that you're just putting lipstick on a pig; and that you can't make any adjustments to, or rebuild at any time. If you like a fresh ride like new, a shock will need to be rebuilt. I would rather spend a few dollars on oil and nitrogen, maybe a seal or two, than on a whole shock when that time comes! It's a rabbit hole that only your wallet can choose! Good luck
I hear you about adding uprated springs on a lower quality shock. Normally, I would have liked to have had my front shocks dyno-ed to find out their spring rate limitation. That said, the OEM shocks seem to be pretty reliable and at around $100 each, pretty cheap to replace.
