Difficulty moving sm10h from frunk to trunk
Brentc
Difficulty moving sm10 from frunk to trunk
Was asking my dealer how difficult would it be to relocate my SENA Bluetooth to the trunk
from the frunk. He said quite involved. Anyone have any insight into this as far as what is involved?
I don't know how involved removing it from your frunk is but putting it in your trunk is quite easy.Go to Motorcycle Dave's website and watch his install video.
motorcycledave.com
Good suggestion
motorcycledave.com
Thanks Paul, I'll do that :thumbup:
You do have to remove all the right side panels in order to remove the cable to the Frunk. Not hard and you will easily do it once the panels are off.
Bob
Sounds pretty cut and dry
Bob
Thanks Bob, I've had those panels off before and it's not so bad. I'm thinking if the dealer says it's going to be an expensive endeavor I'll just do it myself.
Been there, done that. Wouldn't do it again. If you can just get another cable and leave the front one in place. It's not so much that you have to take off all the right side panels, but getting the front end fittings out between the frunk and the frame between the fuse boxes was torture.
I did it myself a couple months ago. It took about 1.5 hours. It wasn't hard to do, but made a world of difference in the way the dongle worked. None of the wires had to be cut to move it. I coiled the extra wire up, and put it in the right rear speaker cavity.
Ray
