So the guy made good on delivering my 2017 RTL all the way from West Texas. Believe it or not, it is better than described, and far better than expected. I can not find one thing I am disappointed with. I gave him an eBay feedback that reflected just how happy I am with the way this guy does business.
Having said that, I did have a small issue that I have seen posted in these very forums, the dreaded difficulty with going in to reverse. It happened to me at the worst possible time as I had most of the road in front of my house blocked, while in position to back in to my driveway. Of course, here comes a pickup truck, and I could not get it to go into reverse. Well I was finally able to, but it was a bit embarrassing for a couple of minutes.
I'm pleased to report that the issue is, at least for now, completely resolved. It was an easy fix, so I wanted to share it here, just in case it might help someone else.
My issues was not with the switch, but more with the plastic actuator. I didn't want to take that what looks like a hard to get and extremely expensive assembly apart unless I absolutely had to. It felt like it wasn't moving well, and the best way to describe it is it kind of mad a creaking noise, and just was not smooth at all. I'm talking about the round button on top you have to press to get it to go in to reverse.
Now this fix felt kind of jackleg, I normally don't like to do this type of thing. But I took a can of Dry Lube, and sprayed just an ever so small amount around the button while I held it down. I figured being dry lube, it would be less likely to draw and hold dirt and debris.
Well it worked way better than expected. I can now get reverse without having to use my right hand, just using my thumb and index finger on my left hand. The first time I tried it, it went in to reverse so easily, I had to check to make sure it actually worked. I think the West Texas sun had just dried out the plastic to the point where it was very hard to press. Not saying this will be a long term fix, but definitely worth a try if you are having this type of issue.
