How do I control the FM Radio on the 2024 RTL?
jzeiler
Well-known member
I did a search and found nothing. I was out on a ride today and decided to select "Radio" and see what I got. Looks like an FM radio, and I figured out how to change station (only via scan) and store station memory locations. I can control the volume. What I could not figure out is how to just enter a station frequency like 92.5. I can scan for it, but it does not stop there. Also, as I ended today's ride, I could not figure out how to turn the radio off. The user manual is of no help, as it just says the radio applet displays radio information, not how to operate it. Was there a separate booklet for just the radio?
This is a 2024 RTL with the 10.25 display.
OK, I did a search on Google and found that a long press on the "ride settings" button will turn the radio off and a long press on the seek button will scroll through available radio stations. I need to go back out and test these methods to see if they work. Why did Can-Am not include this in the manual?
Well, you made me go outside into the cold garage. If your on say 97.5 and press the ">" button, on the display, it should go up one place to say, 97.7. You have to press the ">" on the display.
I also found that you can touch the HD)) 1 2 area to change the station's sub-channel...
Interesting, now I need to go out in the garage and play with my FM radio. Did not know BRP added digital HD radio to the Spyders. A significant upgrade from the very poor FM radio tuners in the 23 and prior bikes. Up until now, I have not even tried the FM radio.
